Coin card collector design. Current UK currency card
Store/Best Sellers
SKU 5318
Coin card design.
This coin card design is a perfect keepsake for saving current UK coins for the future! This design is best cut out of card stock. I recommend using the 216 gsm Docraft branded cardstock #ad https://amzn.to/3B8mVAN and a stick it branded glue pen #ad https://amzn.to/3xeQCPm to make this design.
The design is pre-sized so it will cut at the correct sizing, and comes with files for machines that both have, and have not got the scoring ability. So it can be cut on the Cricut joy / maker / explore and more machines! If using the Cricut joy you will need to use the 12 inch long mat.
All SVG files will load as ‘cut’ files as default, so if you are using the design with scoring lines, you will need to change the score lines to score. First un-group the design, then change the cut operation of score lines in the layers panel to the ‘score’ operation, and then use the 'attach' feature to attach the score lines to the design before clicking 'make it'.
A file without score lines is also included in the download, the design without separate score lines will cut a dotted score line instead.
  • SVG files
  • DXF files
  • EPS files
  • Cricut Design Space
  • Silhouette Studio
  • Brother Canvas workspace
  • Inkscape
  • Illustrator
  • Sure cuts a lot (SCAL)
  • And more!
*Please note, the mock up photos / display photos / money are for illustration purposes only and are not included in the download.
Commercial usage.
Store/Best Sellers
