Daddy keyring charm design, laser SVG. Works with Glowforge and more!
Store/New designs
SKU 00488
Daddy keyring charm design for Glowforge laser cutters and more!
Cut the design out of wood or acrylic on your laser cutter using the cut and engrave settings (engrave the black, cut the red). I cut the design in the photo out at 1.8 inches in height, but you are welcome to choose your own sizing according to your own preference.
The children's names in the photo are not included in the download. Your design will be blank for you to personalise yourself.
The files have been tested and cut out on a Glowforge laser cutter.
This product is a digital artwork as shown in the images, sent to you as an instant digital download of files (No physical product will be sent to you).
The files included in this digital download are a zip file containing an:
  • SVG file
  • DXF file
  • EPS file
  • PDF file
Commercial usage.
Store/New designs
