Easter egg ornament laser cut design for Glowforge machines and more
Store/Best Sellers
SKU 5888
$2.99
was $4.99 Save 40%
Easter egg ornament laser file design.
This design is so pretty! Perfect for decorating your home ready for Easter! depending on your width of wood, you can choose to just cut one backing piece or cut out two to make it stand up better / sturdier. To make the ornament, simply glue the pieces of wood together.
The design is quick and easy to cut out on a laser cutter. You are free to resize the design to suit. I cut the design in the photo at 5 inches in height.
This file has been cut and tested on the Glowforge basic machine.
  • SVG files
  • DXF files
  • EPS files
  • PDF files
*Please note, the mock up photos / display photos are for illustration purposes only and are not included in the download.
Commercial usage.
Store/Best Sellers
