Jigsaw laser cut design for Glowforge machines and more
Store/Best Sellers
SKU 5880
$2.99
was $4.99 Save 40%
Jigsaw laser file design.
This jigsaw design is suited for adults, as it can be quite difficult to solve! A cheat sheet for those that are struggling to solve the design is included in the download :-)
The design is quick and easy to cut out on a laser cutter. You are free to resize the design to suit. I cut the design in the photo at 6 x 6 inches
This file has been cut and tested on the Glowforge basic machine.
  • SVG files
  • DXF files
  • EPS files
  • PDF files
*Please note, the mock up photos / display photos are for illustration purposes only and are not included in the download.
Commercial usage.
Store/Best Sellers
