Robot bracelet charm, laser cutting file for glowforge and more.
Store/New designs
SKU 5972.2
Robot bracelet charm design for Glowforge laser cutters and more!
Simply cut the design out of wood or acrylic on your laser cutter using the cut and engrave settings (engrave the black, cut the brown), and then once cut use a black elastic string to make this design into a bracelet. I cut the design in the photo out at 1.5 inches in height, but you are welcome to choose your own sizing according to your own preference. I also coloured mine in with sharpie pens.
I used glowforge medium draftwood to make these and:
Black elastic: #ad https://amzn.to/3JWjVwo
Acrylic pens: #ad https://amzn.to/4a2MS4b
These files have been tested and cut out on a Glowforge laser cutter.
This product is a digital artwork, sent to you as an instant digital download of files. No physical product will be sent to you.
  • SVG file
  • DXF file
  • EPS file
  • PDF file
Commercial usage.
Store/New designs
