Snowman 3D Shadow Box Design
Store/Best Sellers
SKU 6074
$2.99
3D Snowman Shadow Box Design
Add a festive touch to your home with this adorable 3D Snowman Shadow Box design! This easy and fun project features 4 layers of cardstock (plus the snowman's hat and scarf), creating a captivating layered effect that brings your snowman to life.
To assemble, simply cut each layer from cardstock and stack them in the correct order, using glue or sticky foam dots to stick the layers together. If you’re unsure of the layer order, load the design into your cutting software, ungroup the layers, and arrange them on your canvas for guidance. It's that simple! Perfect for snowman lovers and holiday decor enthusiasts!
Find a you tube assembly video here:
I used 216 gsm textured cardstock and sticky foam dots to assemble this design together.
The textured cardstock can be found on amazon here: #ad https://amzn.to/3x7tllR
The sticky foam dots can be found on amazon here: #ad https://amzn.to/3xdlymp
The box frame I used can be found on amazon here: #ad https://amzn.to/4aR9YeF
This product is a digital artwork as shown in the images, to cut and make your own shadow box sent to you via email as an instant digital download of files (No physical product will be sent to you).
· SVG file
· DXF file
· EPS file
· Cricut Design Space
· Silhouette Studio
· Brother Canvas workspace
· Inkscape
· Illustrator
· Sure cuts a lot (SCAL)
· And more!
Commercial usage.
Store/Best Sellers
Christmas tree design
Rabbit face designs
Rabbit face designs
Rabbit face designs
Boat design
Boat design
Boat design
Cat paper cut design
Ice Hockey designs
Ice Hockey designs
Ice Hockey designs
